Hello, Just wanted to ask if somebody successful already tried to backport a Calypso program to a lower version. I know if you change the version in the File “Version”, but this is only working from 6.x to 6.x, afterwards with an higher version its no longer working with that trick. Soooo, is there a solution for this? Or does nobody else has this struggle some times  Thanks in advance, Regards,
