[3b...] Posted July 14, 2022 Share Posted July 14, 2022 Hi, Im looking for some solution to my problem or/and another way to follow. I have a characteristics list separated by groups because this is the way to inspect the part 2 time faster and do not use the clearance cube, this is necessary for the process because we inspect 100% the parts. I want to know how can I do to inspect a group list but just when the part number meets the condition... in example we run 20 types of parts every part have 4 subfamilies... A1, A2, A3, A4... the numb 1 and numb 2 are pretty similar but the 3 and 4 is the same geometry except by 5 additional features. When the part is A1 or A2 run the program except the characteristic group mentioned, and when the part be A3 or A4 need to measure these characteristics... Is not an option to run the routine by characteristic list, just for features list...the condition option by characteristics works fine but this increase the time inspection. I appreciate your help, thank you. Link to comment Share on other sites More sharing options...
[Is...] Posted July 14, 2022 Share Posted July 14, 2022 Actually, running from Characteristics is faster, but looks like is not popular to deal with the execution order using this list. I normally save from 30 to 80 seconds in programs that take around 12 minutes. is not necessary to use PCM for that but I do it sometimes: viewtopic.php?p=31310#p31310 Link to comment Share on other sites More sharing options...
[3b...] Posted July 14, 2022 Share Posted July 14, 2022 Let me take a look for your information, hope works! 🙂 Gracias. Link to comment Share on other sites More sharing options...
[3b...] Posted July 14, 2022 Share Posted July 14, 2022 Please sign in to view this quote. I was very focused to fix this issue with a complex PCM command and after many trials I understood... always was a simple command: //********************MINI PLAN******************** //select if the part is a production or set-up part repeat definer_2=0 MINIPLAN=inquireList("TIPO DE MEDICIÓN","SHORT","AUDIT") if MINIPLAN=="SHORT" then definer_2=1 endif if MINIPLAN=="AUDIT" then definer_2=1 endif if definer_2==0 then message("SELECCIONA UNA OPCIÓN DE LA LISTA o PRESIONA ESC EN EL JOYSTICK PARA VOLVER A CARGAR DATOS") endif until definer_2==1 setRecordHead("u_MINIPLAN",MINIPLAN) //********************COMPRESSOR SIZE "H1"******************** if PARTSIZE=="H1" then NEWPATH=PARAMETERPATH+"ORBITING_FINISHING_57001366_142.para" readPCMFile(NEWPATH) PARTEXT="142" PARTNUMBER="57001366" PARTREV="H" loadCADFile(CADPATH+"ORBITING_FINISHING_57001366.sab") //********************ALIGNMENT******************** copyFile(BASEALIGNPATH+CMMID+BS+PARTFAMILY+TAB+OPERATION+TAB+FAM3+BS+DAT,BASESYSTEMPATH+PROGRAMNAME+BS+DAT) copyFile(BASEALIGNPATH+CMMID+BS+PARTFAMILY+TAB+OPERATION+TAB+FAM3+BS+USE,BASESYSTEMPATH+PROGRAMNAME+BS+USE) copyFile(BASEALIGNPATH+CMMID+BS+PARTFAMILY+TAB+OPERATION+TAB+FAM3+BS+VER,BASESYSTEMPATH+PROGRAMNAME+BS+VER) //********************MINIPLAN SELECTION******************** if MINIPLAN=="SHORT" then setRunID("SHORT") endif if MINIPLAN=="AUDIT" then setRunID("AUDIT") endif endif //********************COMPRESSOR SIZE "H7"******************** if PARTSIZE=="H7" then NEWPATH=PARAMETERPATH+"ORBITING_FINISHING_57007481_132LOVI.para" readPCMFile(NEWPATH) PARTEXT="132 LOVI" PARTNUMBER="57007481" PARTREV="A2" loadCADFile(CADPATH+"ORBITING_FINISHING_57007481_132LOVI.sab") //********************ALIGNMENT******************** copyFile(BASEALIGNPATH+CMMID+BS+PARTFAMILY+TAB+OPERATION+TAB+FAM3+BS+DAT,BASESYSTEMPATH+PROGRAMNAME+BS+DAT) copyFile(BASEALIGNPATH+CMMID+BS+PARTFAMILY+TAB+OPERATION+TAB+FAM3+BS+USE,BASESYSTEMPATH+PROGRAMNAME+BS+USE) copyFile(BASEALIGNPATH+CMMID+BS+PARTFAMILY+TAB+OPERATION+TAB+FAM3+BS+VER,BASESYSTEMPATH+PROGRAMNAME+BS+VER) //********************MINIPLAN SELECTION******************** if MINIPLAN=="SHORT" then setRunID("SHORT") endif if MINIPLAN=="AUDIT" then setRunID("VVI") endif endif Link to comment Share on other sites More sharing options...
