composite best fit values
I know it's been discussed before. Can someone tell me how to extract the values of translation and rotation when using a bolt pattern (composite position) ? It is displayed in PiWeb when plot view is selected, however I can't find the "get" command to put it into a result element . I want it exported in the excel output.
ok, I figured it out. If you select the position characteristic, AND drill down, the actuals are available. As always deg() is required to get out of radians. I dropped it into result element.
