Clearance Planes and Safety Cube
I'm stumped. I created a routine for a single fixture using a Contura G2 2014 with a Vast XXT, articulating head. We have built an Auto-Run Fixture, so I changed to a Star Probes to eliminate the Articulations because of spacing issues between the parts. I then adjusted my safety cube so the star probe wouldn't crash into the other stations. Well, that didn't work. Where the stylus should be .250 form the part, it's 6 inches off of the part and into the next part's station. For some reason it still see's the articulation, I'm guessing. There are 32 parts in this part family and I do not want to re-write all of them with the new probe, I'm looking for a stetting to adjust for this. Can some one HELP? Pulling out what's left of my hair!
Have you considered using +Z clearance planes? When using CP-Y you're going to have to clear the quill, too. It's not as bad on CP-X and CP+X. And, not an issue on CP+Y. Using CP+Z will rely on the Clearance Distance (and possibly position points) for the necessary clearance.
Tom, I've considered it but have been hesitant because of the shape of the part. I will give it a try, I may have to put some manual points in to clear it. I am hoping to find a simpler solution but it's Monday, so there is that.
