[Lo...] Posted July 11, 2022 Share Posted July 11, 2022 I'm stumped. I created a routine for a single fixture using a Contura G2 2014 with a Vast XXT, articulating head. We have built an Auto-Run Fixture, so I changed to a Star Probes to eliminate the Articulations because of spacing issues between the parts. I then adjusted my safety cube so the star probe wouldn't crash into the other stations. Well, that didn't work. Where the stylus should be .250 form the part, it's 6 inches off of the part and into the next part's station. For some reason it still see's the articulation, I'm guessing. There are 32 parts in this part family and I do not want to re-write all of them with the new probe, I'm looking for a stetting to adjust for this. Can some one HELP? Pulling out what's left of my hair! Link to comment Share on other sites More sharing options...
[To...] Posted July 11, 2022 Share Posted July 11, 2022 Have you considered using +Z clearance planes? When using CP-Y you're going to have to clear the quill, too. It's not as bad on CP-X and CP+X. And, not an issue on CP+Y. Using CP+Z will rely on the Clearance Distance (and possibly position points) for the necessary clearance. Link to comment Share on other sites More sharing options...
[Lo...] Posted July 11, 2022 Author Share Posted July 11, 2022 Tom, I've considered it but have been hesitant because of the shape of the part. I will give it a try, I may have to put some manual points in to clear it. I am hoping to find a simpler solution but it's Monday, so there is that. Link to comment Share on other sites More sharing options...
[To...] Posted July 11, 2022 Share Posted July 11, 2022 see attached example of measuring circle on -Y side. 1st 3 pages show positions using CP-Y and 2nd 3 pages show positions using CP+Z.CP-Y vs CP+Z.pdf Link to comment Share on other sites More sharing options...
[Lo...] Posted July 11, 2022 Author Share Posted July 11, 2022 This is the shape I'm dealing with. So it looks like I may have to add some move points. Tom, your images made perfect sense. It's not going to be an easy change but worth it in the end.Capture.PNG Link to comment Share on other sites More sharing options...
