Re-measure with different measurement element
hello everybody,
is it possible to change the the element for example in a parallicity if the result is out of tolerance.
for example i use plane1 to check parallicity (to another plane), measurement is out of tolerance, now i want calypso to measure plane2 and use it instead of plane1 for this exact parallicity, but only if plane1 is out of tolerance. if plane1 is in tolerance, plane2 shouldnt be measured at all to save time)
is something like this possible?
sry for my english
Best wishes
Daniel
thanks, i think thats waht i needed, but instead of the primary datum i need to change the feature. could u tell me what would be the command o get the featue name instead of getNominal().referenceA.name fo the datum name
and thanks again for you help 🙂
greetings
Daniel
