Hi,
I have a problem with the script recorder to take the image of a 3D comparison. I want to take the image of whole part, and when I record using the function "Reset Zoom" it succeed, but when I run the script it doesn't work. The first is the image taken when I record the script, the second one is the image taken running the script. The part is cut. And this is the code I used. Why it doesn't work? I am wrong with something? Thank you very much.
# -*- coding: utf-8 -*-
import gom
gom.script.cad.show_element_exclusively (elements=gom.ElementSelection ({'category': ['key', 'elements', 'part', gom.app.project.parts['Part'], 'explorer_category', 'inspection', 'object_family', 'surface_comparison', 'type', 'surface_comparison']}))
gom.script.view.adapt_zoom (use_animation=False)
gom.script.report.create_report_page (
	animated_page=False,
	animation=['snapshot_frame_6', 'Animation by all stages, 12.0s (2)'],
	imitate_fit_mode='overwrite',
	template_name='Report_Bitron_A4_Horizontal_Stage_Vecchio_Nuovo_a4',
	template_orientation='landscape',
	template_package={'name': 'Bitron', 'uuid': '11a448bd-b5a9-4f56-acfe-5d55966554dc', 'version': '1.0.79'},
	title='$format (page_number, "", show_unit=false, date_format=\'dd/MM/yyyy\')$ - $format (number_of_pages, "", show_unit=false, date_format=\'dd/MM/yyyy\')$')
https://qualityforum.zeiss.com/topic/1007-problem-with-reset-zoom-in-script/
Hi , i guess one question here is ' why do you want to do this ' .  My guess : you have lots of different parts that you want to evaluate and you always want to have certain views from surface comparisons?  As such feels like a job for a script?
The views in reports are not so easy to handle via code and ive never found anything completely robust.
Maybe you can clarify why you want to do this and there may be a different way or something for the software development to think about.
Hi James,
thank you for your response! I have to do this because I have made a script that automatically, starting from a actual/CAD comparison, make a actual/actual comparison (example: actual part on past month part) and automatically generate 8 views for see the comparison all around. I created a report style with eight placeholder for 3D view and in the first one I have the problem reported in this thread.
I hope I explained myself.
Thank you very much for your support!
Hey Marco, i would go a different way here.   I would use a project with two parts.
  One part containing cad , one part containing a nominal stl that is the ' month before ' .
Now this month before model would need exporting in the appropriate alignment.
The alignment of the current part will be to cad - then in that alignment do a comparison to the nominal mesh in the other container.
In this way you can  set up all your views you need.
Then when next month happens you can exchange the nominal mesh for a new nominal mesh .
The parametrics will then deal with the reporting and views - as they are linked to the nominal mesh and subsequent child surface comparison.
It then depends how complex you want to or need to get  as you might use code to search for stls in a directory with certain names or dates and do this exchange
I really hope this makes sense!!
It is always my goal to make best use of the parametrics !!
