[Me...] Posted July 4, 2022 Share Posted July 4, 2022 Hallo all, is possible to read out the used value of the filter of a cone with a PCM command. similar to getActual("Cone").diameter, but I want to read the value of the filter instead of diameter. I can't find filters as attributes in the PCM command list, but some things aren't there and still work. I hope, someone knows something. Thanks ! Link to comment Share on other sites More sharing options...
[Is...] Posted July 4, 2022 Share Posted July 4, 2022 ... Link to comment Share on other sites More sharing options...
[Me...] Posted July 5, 2022 Author Share Posted July 5, 2022 Hallo Israel, thank you for your answer. I have still one question What is the difference between ....To and without To. I have tested. For the cone it is the same result, but not for the line, why ? Link to comment Share on other sites More sharing options...
[Is...] Posted July 5, 2022 Share Posted July 5, 2022 Is because for band-pass you have two values (from - to) and even if this type of evaluation is not enabled the values are there…2022-07-05_09h30_04.png Link to comment Share on other sites More sharing options...
[Me...] Posted July 5, 2022 Author Share Posted July 5, 2022 Thank you, it is the solution. A nice day and see you again .... Link to comment Share on other sites More sharing options...
