save/load defaults question under resource tab
When I go into save/load . I have settings that are saved. When i enable it on this screen and then go to the features to view to see if the filters/outliers have been applied, the boxes are unchecked. Is there a sequence of steps tat has to be done?
If you activate filters and outliers thru Save/Load Defaults, they are applied automatically on the characteristics. So, even though the features do not have them active, the characteristics will have them. Bottom line, the results on the printout are the same. Only downside to this is the features used in Base Alignment will not have filters/outliers on them. Manually turn those on if desired
