Error when dragging characteristic - Calypso 2018-202 related
Hi all,
We upgraded to Calypso 2018 about 2 years ago and just recently to the 2020 version. In one of our workstations, we get (3) Calypso "popup" errors whenever a characteristic is dragged to a new location. Oddly enough, when working on the feature side I can drag and drop to my hearts content with no errors...
Has anyone else ran into this?
Thanks ahead of time for any input
Rick, Thanks for taking the time to investigate. Here is the text from the error message>>
SYSTEM STATE
CALYPSO
Inspection: 24ZE-1227-54092
Creation software version: 4.4.06.06
Date and time: #(23 June 2022 13:25:48)
additionalChanges:
6/15/22 / 10:00:47 A ...\data\sesamdata\calypso_start
96633_lengthUnit_qdasRoughness.st
OMPiWebCMM-headerFileForCharacteristic.st
renameCharInTableFile_8.st
Renaming_Miniplans_Bugfix.st
Actual characteristic: Length of perpendicular Width at NO GO end
Actual feature: Plane Plane3
Creation DME: PRISMO
Hostname: WGC1101DYK7X2
Mancnc active: false
Navi mode: automatic
Run mode: manuel
OS Windows 10 Enterprise win32 V6.2 nt i386 ucs2
CMM-OS
Actual configuration: sammy5
Actual stylus: -Z
fwObject: Zeiss.CMMOS.OMControlBehaviourC99FW20
ID chain CS: 0020W5B2,000EPZPU
IFCpresent: false
ncDisplayStatus: 33-----#--------
PICS A input: +0
SDO version: 6.5.0.18
Sensor: VASTXT
TCO pending: 0
QDAS converter 1.98
PiWeb reporting
PiWeb reporting version: 6.6.8.0
PDF Merger: GPL Ghostscript 9.06 (2012-08-08) Copyright (C) 2012 Artifex Software, Inc. All rights reserved.
OBJECT
a HandleRegistry protected by a RecursionLock with (535->Cursor vertical drag 242->Cursor write 15409->Cursor blank 19186->Cursor zoom 19134->Cursor UpDownCursor 492->Cursor database 259->Cursor read 22797->Cursor crossHair 146->Cursor normal 147->Cursor xeq 148->Cursor wait 149->Cursor compactMemory 150->Cursor quickGarbage 151->Cursor garbage 20271->Cursor Zeiss.Calypso.OMMGeometry-Cursor 19623->Cursor LeftRightCursor 15913->Cursor Aragon column resize 288->Cursor fingerPointer 348->Cursor textMarker )
executors->#(nil nil nil nil Cursor vertical drag nil Cursor write nil nil nil Cursor blank Cursor zoom nil nilsize nil nil nil nil nil nil nil nil nil Cursor fingerPointer Cursor textMarker nil nil nil nil nil) accessLock->a RecursionLock tally->19 valueArray->WeakArray (nil nil nil nil Cursor vertical drag nil Cursor write nil nil nil Cursor blank Cursor zoosize nil nil nil nil nil nil nil nil nil Cursor fingerPointer Cursor textMarker nil nil nil nil nil)
METHODSTACK
Unhandled exception: a primitive has failed
HandleRegistry>>evaluateWithFullProtection:
HandleRegistry>>registerValueOf:
Cursor class(OSHandle class)>>registerValueOf:
optimized [] in OSHandle>>handleValue:
BlockClosure>>ifCurtailed:
Cursor(OSHandle)>>handleValue:
Cursor>>privateInstall
Cursor>>beCursor
Cursor class>>currentCursor:
Cursor>>show
Zeiss.CMMOS.OMScrollingCanvas>>dragFeedback:dropSource:
ConfigurableDropSource>>giveFeedback:
DragDropManager>>mouseMovedTo:in:
DragDropManagerTracker>>mouseMovedEvent:
MouseMovedEvent>>dispatchTo:
DragDropManagerTracker(SelectionTracker)>>handleEvent:
EventDispatcher>>dispatchEvent:
MouseMovedEvent(Event)>>dispatch
MouseMovedEvent(Event)>>dispatchForWindowManager:
optimized [] in WindowManager>>safelyDispatchForWindowManager:
BlockClosure>>on:do:
WindowManager>>processNextEvent
optimized [] in [] in WindowManager>>newProcess
optimized [] in WindowManager>>newProcess
optimized [] in Process class>>forBlock:priority:
#endOfMessage#
I am going to guess that a Calypso 4 program is having issues running in the new software. Maybe try creating a new program, set the Base Alignment, copying and pasting with references?
This would probably be easiest to do.
You could also try running as if it was version 4.4.
Go to:
Resources
--Compatibility Settings
----for this Measurement Plan
(scroll down to the bottom of the dialog box and look for)
------Performance as if create with Rev.
Then use the drop down dialog and select version 4.4
The error occurs on new programs and old programs without fail. I'll try the versioning to see if this has an effect.
The PiWeb references has me wondering if it is related to the issue.
I have a Prismo that is being retrofitted with ROTOS capabilities. The tech was having issues until he deleted the sesamdata folder shown in the error message. I'm thinking of making a backup of this folder and moving it temporarily to see if it has a positive effect.
Thanks for your suggestions!
