[Da...] Posted May 20, 2022 Share Posted May 20, 2022 Search engine blocks me from sphere measurement problem how to and combination of them so i have to write another one. How you measure the sphere ? i used 3d curve becouse i cannot figure out another way. Link to comment https://qualityforum.zeiss.com/topic/10154-sphere-i-do-not-know/ Share on other sites More sharing options...
[Ma...] Posted May 20, 2022 Share Posted May 20, 2022 There is a "sphere" feature containing all the necessary measuring strategies, similar to circle, plane and cylinder features. Does this answer your question? Link to comment https://qualityforum.zeiss.com/topic/10154-sphere-i-do-not-know/#findComment-48440 Share on other sites More sharing options...
[Da...] Posted May 21, 2022 Author Share Posted May 21, 2022 i tryed this but i fail, i do not understand how to do it i need to scan it for form so i wanted many points i think in sphere was something what gived sphere but from 5 points or something very simple Link to comment https://qualityforum.zeiss.com/topic/10154-sphere-i-do-not-know/#findComment-48442 Share on other sites More sharing options...
[Er...] Posted May 24, 2022 Share Posted May 24, 2022 I would use the circle path. In the circle path set the number of paths I want. Then set the two heights. If the CAD extracts correctly I can compare the paths to the CAD. Link to comment https://qualityforum.zeiss.com/topic/10154-sphere-i-do-not-know/#findComment-48444 Share on other sites More sharing options...
[SH...] Posted May 24, 2022 Share Posted May 24, 2022 Please sign in to view this quote. Actually it is Einstein's words not mine, please correct it . Link to comment https://qualityforum.zeiss.com/topic/10154-sphere-i-do-not-know/#findComment-48446 Share on other sites More sharing options...
[Er...] Posted May 24, 2022 Share Posted May 24, 2022 If you want to scan, I would suggest using the Helix Path Option. Then, you just need to fill in necessary info within the Helix. I would scan slow, and I typically start at the bottom of an ID Sphere or Top of the OD sphere which is usually 1/2 the sphere diameter, which you enter for your start height, determine your target height, and how many rotations necessary to scan. It will calculate your gradient slope from these values. I have learned that if your sphere is not normal to the Alignment, then may not scan correctly. Maybe someone smarter then myself knows how to change this. For this instance, I scan several circled paths, which work great for form as well. If you use the Circles, you will need to change the axis for the different paths you are after. Link to comment https://qualityforum.zeiss.com/topic/10154-sphere-i-do-not-know/#findComment-48448 Share on other sites More sharing options...
[Ch...] Posted May 25, 2022 Share Posted May 25, 2022 Please sign in to view this quote. try using google. e.g. site:viewforum.php?f=13 measurement https://blog.hubspot.com/marketing/how- ... ite-search Link to comment https://qualityforum.zeiss.com/topic/10154-sphere-i-do-not-know/#findComment-48450 Share on other sites More sharing options...
[Da...] Posted June 23, 2022 Author Share Posted June 23, 2022 Sorry Shabu pv probobly my destination was to work in goverment administration - this insane language is my nightmare sometimes... Thank you for answers : ) searching also works with duck duck, this is super https://duckduckgo.com/?q=site%3A+forum ... era&ia=web Link to comment https://qualityforum.zeiss.com/topic/10154-sphere-i-do-not-know/#findComment-48452 Share on other sites More sharing options...
