I could use some math help.
This can be problematic - for calculation you need more then just these two numbers. As Clarke wrote - you need R and angle.
All i found was trials - each repetition you are comming closer to result.
SolidWorks denies to work ( radius will be very big ).
Found Hugens derived formula ( don't know if it helps ): 3001_ec9c633a9915f87288ac62b5086c0854.png
Well we know
M = 1079.54897 (Actual measured value)
C-D = 2.31460 (Actual measured value assumed from "Form")
I think I need to calculate "m".
I wasn't able to create a reliable circle in Calypso, I attempted with the same data 4 times, it resulted in four different diameters.
