weeping from scale.
Pretty normal. It is a heavy grease/oil that is used to hold scales on ceramic in order to allow contraction and expansion of machine without affecting scales.
Did you free the bug or put it out of its misery?
Yeah, fairly common.
In fact, I was weeping when I stepped on the scale this morning. 🤣
Damn Covid quarantine weight isn't disappearing. 🙄
Thanks for the replies and the good news.
I smashed the critter right there.
Wiped it off, (you can't it's smear).
Now nothing is coming into spec now.
STUPID BUG!!
I've noticed this on CMMs where the temperature has gone upwards of 80 degrees or so, high temps seem to allow some run off.
