[Da...] Posted June 15, 2022 Share Posted June 15, 2022 I haven't had to do this kind of alignment in years. I have a part that has the Z zero location buried in a fixture and completely un-accessible. I am trying to align a model , using another plane. but each time I try , I get alignment not possible. How do you handle this situation ? Link to comment https://qualityforum.zeiss.com/topic/10226-alignment-issue/ Share on other sites More sharing options...
[Ro...] Posted June 15, 2022 Share Posted June 15, 2022 Make sure all your Rotational boxes are showing the correct direction. In this case my A plane is on the left side of the part, so -X, but if i messed up and selected +Z instead, Calypso would be confused.fhjfhjdgfhjdgfhjd.PNG Link to comment https://qualityforum.zeiss.com/topic/10226-alignment-issue/#findComment-48840 Share on other sites More sharing options...
[Da...] Posted June 15, 2022 Author Share Posted June 15, 2022 I need the results to come from the intended Z zero... So I'm assuming I need to use an offset plane? Link to comment https://qualityforum.zeiss.com/topic/10226-alignment-issue/#findComment-48842 Share on other sites More sharing options...
[Ma...] Posted June 15, 2022 Share Posted June 15, 2022 Special -> Transform in Z Link to comment https://qualityforum.zeiss.com/topic/10226-alignment-issue/#findComment-48844 Share on other sites More sharing options...
[To...] Posted June 15, 2022 Share Posted June 15, 2022 Another option would be to create a program to measure a base alignment on the fixture with no part. Do a manual alignment, followed by a cnc alignment. In the BA window of your part program, select Load Base Alignment and select the fixture alignment(cnc) from above. Then, create a secondary alignment for the part origin (minus the Spatial and Z origin) and use this alignment for all of your part features. I'm thinking this thru in my head so I'm not sure if I've missed anything. Link to comment https://qualityforum.zeiss.com/topic/10226-alignment-issue/#findComment-48846 Share on other sites More sharing options...
[Er...] Posted June 15, 2022 Share Posted June 15, 2022 Anymore I just make a Base Alignment to the part. Calypso has gotten confused when CMM +Z and BA +Z are not the same. Then a secondary alignment for part print coordinates. Link to comment https://qualityforum.zeiss.com/topic/10226-alignment-issue/#findComment-48848 Share on other sites More sharing options...
