[Je...] Posted June 7, 2022 Share Posted June 7, 2022 . In your answer, do not consider the potential workload this would create. Only consider if you deem your machine capable of verifying class X .0001" gauge pins. Feel free to list your machine and/or its most recent accuracy statement in the comments (uncertainty ratio). We are considering taking on this project, so I wanted to poll the masses. . Link to comment https://qualityforum.zeiss.com/topic/10260-would-you-use-your-companys-highest-accuracy-cmm-to-verify-class-x-0001quot-gauge-pins/ Share on other sites More sharing options...
[Ri...] Posted June 7, 2022 Share Posted June 7, 2022 So who owns the Xenos or an extremely well tuned small Prismo Ultra/Micura? Link to comment https://qualityforum.zeiss.com/topic/10260-would-you-use-your-companys-highest-accuracy-cmm-to-verify-class-x-0001quot-gauge-pins/#findComment-49046 Share on other sites More sharing options...
[Je...] Posted June 7, 2022 Author Share Posted June 7, 2022 Please sign in to view this quote. We have an extremely well tuned Prismo Ultra in a controlled lab. I think it can handle the task, but we'll do some MSA before approving the process. Link to comment https://qualityforum.zeiss.com/topic/10260-would-you-use-your-companys-highest-accuracy-cmm-to-verify-class-x-0001quot-gauge-pins/#findComment-49048 Share on other sites More sharing options...
[Ri...] Posted June 7, 2022 Share Posted June 7, 2022 Please sign in to view this quote. You'd be interested to know that a lot of labs that certify pin gages do not meet a less than 10% uncertainty. Link to comment https://qualityforum.zeiss.com/topic/10260-would-you-use-your-companys-highest-accuracy-cmm-to-verify-class-x-0001quot-gauge-pins/#findComment-49050 Share on other sites More sharing options...
[Je...] Posted June 7, 2022 Author Share Posted June 7, 2022 Richard, That is one reason we are considering bringing this in-house. The service we've been using has sent back some questionable results, and I wonder if the barely skilled new hires get assigned to pin gauge calibration. Link to comment https://qualityforum.zeiss.com/topic/10260-would-you-use-your-companys-highest-accuracy-cmm-to-verify-class-x-0001quot-gauge-pins/#findComment-49052 Share on other sites More sharing options...
[Ri...] Posted June 7, 2022 Share Posted June 7, 2022 Please sign in to view this quote. In my old life, we got burned by a reputable ring gage manufacturer and the 3rd party certification. Sold a lot of bad parts to a customer because the ring gages were used as setting masters for an air gage. A quick check on our Accura (1.2 micron spec) quickly showed that the gages were not what they were certified at. It certainly caused a lot of issues and made people question a lot of gages out on the floor. Link to comment https://qualityforum.zeiss.com/topic/10260-would-you-use-your-companys-highest-accuracy-cmm-to-verify-class-x-0001quot-gauge-pins/#findComment-49054 Share on other sites More sharing options...
[Da...] Posted June 8, 2022 Share Posted June 8, 2022 Just left the company, but we had 4 highly tuned micuras (.7 micron machines that calibrate at about 1/2 that number) and YES I wound VERIFY, down to XXX pins and rings. I would never calibrate down to that level, but they could easily verify if it was a reasonable match to the calibration cert. Link to comment https://qualityforum.zeiss.com/topic/10260-would-you-use-your-companys-highest-accuracy-cmm-to-verify-class-x-0001quot-gauge-pins/#findComment-49056 Share on other sites More sharing options...
[Je...] Posted June 8, 2022 Author Share Posted June 8, 2022 Please sign in to view this quote. That's an important distinction, Dave. Thanks for highlighting it. Link to comment https://qualityforum.zeiss.com/topic/10260-would-you-use-your-companys-highest-accuracy-cmm-to-verify-class-x-0001quot-gauge-pins/#findComment-49058 Share on other sites More sharing options...
[Ma...] Posted June 8, 2022 Share Posted June 8, 2022 Please sign in to view this quote. I try not to get hung up too much with the vocabulary of metrology but I have been mired in this particular one in the past. Officially "Gage verification" is I believe what most of the world considers "gage calibration". A gage is considered "calibrated" when it's bias and uncertainty has been determined. A gage is considered "verified" when it's calibration values have been determined to meet some specifications or fitness for use. 😱 I wish there was an exploding head Smilie Link to comment https://qualityforum.zeiss.com/topic/10260-would-you-use-your-companys-highest-accuracy-cmm-to-verify-class-x-0001quot-gauge-pins/#findComment-49060 Share on other sites More sharing options...
[Ri...] Posted June 8, 2022 Share Posted June 8, 2022 I would label it as certification vs calibration. Certification is what is performed on these pins after they are manufactured. You are saying their dimensions/characteristics are these values. Like Mark said, you are taking into account measurement uncertainty. Calibration is when something is changed to make it measure or read a certain value. Ring Gages/Pin Gages typically cannot be calibrated, but they can be certified. A scale or a CMM is something that is typically calibrated, and it is calibrated with artifacts that are certified with known measurements. This is also why we try to correct people, and call it probing qualification. We are quantifying the actuality of the stylus, we are unable to change the values. Link to comment https://qualityforum.zeiss.com/topic/10260-would-you-use-your-companys-highest-accuracy-cmm-to-verify-class-x-0001quot-gauge-pins/#findComment-49062 Share on other sites More sharing options...
[An...] Posted June 9, 2022 Share Posted June 9, 2022 i voted for "yes". but I would only perform a calibration if the laboratory environment is optimal. Is the humidity optimal? small climate fluctuations ±0.5 degrees? Basic calibration of the CCM optimal? We are a manufacturer of plastic parts and our measurement laboratory in tempered to 22.5 degrees and have a temperature change of ±0.5 degrees with humidity of 50-60%. These values are optimal for our plastic parts. Even if our values are stable, I would not do my own calibration of measuring pins at the moment, because our temperature is higher than it should be for metal parts ( 21 degrees ). Link to comment https://qualityforum.zeiss.com/topic/10260-would-you-use-your-companys-highest-accuracy-cmm-to-verify-class-x-0001quot-gauge-pins/#findComment-49064 Share on other sites More sharing options...
[Ow...] Posted June 9, 2022 Share Posted June 9, 2022 I'd be a bit apprehensive about it. Along with the many previous reasons mentioned, some quality standards require 3rd party (fox not watching the hen house) calibration procedures and then considering the time added to a busy CMM that is not going to be as quick as modern calibration equipment. For around 50-60K, you can get this_ https://gagemaker.com/precision-gage-ca ... n-systems/. A bit more expensive but cheaper than a CMM, you can't go wrong with Pratt & Whitney calibration equipment either. Link to comment https://qualityforum.zeiss.com/topic/10260-would-you-use-your-companys-highest-accuracy-cmm-to-verify-class-x-0001quot-gauge-pins/#findComment-49066 Share on other sites More sharing options...
[Je...] Posted June 9, 2022 Author Share Posted June 9, 2022 Please sign in to view this quote. Thank you, Owen. I am going to bring that technology up to our team. You also make good points about machine burden and bias. Link to comment https://qualityforum.zeiss.com/topic/10260-would-you-use-your-companys-highest-accuracy-cmm-to-verify-class-x-0001quot-gauge-pins/#findComment-49068 Share on other sites More sharing options...
