Missing probes in stylus system management window
This morning I ran a qualification program for a part, one of the probes showed yellow. I went into the Stylus System Management window and the probe was not listed as well as the next probe. Next I went into the Probing System qualification window and the probes are listed there. The probes in question are the 083 and 084 probes.
Does anyone know why this would happen or how to fix it so the probes will show up in the stylus system management window?
My last resort would be to delete the probe and import it back in to see if there is still an issue. 240_49e67bdaa237e42f3cc1dfd6080f0c02.jpg
Look at the bottom of your list. The Styli Available list appears to be sorting alphanumerically and since 8 comes after 0, it will be at the bottom of the list. Fortunately, you can rename the styli to 083 and 084....
