[Mi...] Posted June 8, 2022 Share Posted June 8, 2022 Loaded up the new 2022 (7.4) and now I am getting this message from PiWeb. Id love to right click and give permission but WHERE do I RC? Tried the shortcut on the desktop but I get nothing.... Throws up this message as soon as I open up a prg. Link to comment Share on other sites More sharing options...
[d8...] Posted June 8, 2022 Share Posted June 8, 2022 You will need go to go C:\Program Files\Zeiss\PiWeb (or wherever your PiWeb program files are located) Find Designer.exe, Monitor.exe, Planner.exe (basically, any .exe that you use in PiWeb) and right click --> Properties. Unblock. There's one more solution but this is the easiest so I would try this first. Link to comment Share on other sites More sharing options...
[Mi...] Posted June 8, 2022 Author Share Posted June 8, 2022 Hey Laura... I clicked every exe file on this pc and have yet to find one that has the security option in your snippet. Whats the other way you mentioned? Funny thing is, yesterday it worked ok. I could see the data base and looked around all the new templates in 2022 etc... Today I get locked out. Only thing I did was change the save paths for my pdf file from 7.2 to 7.4. Link to comment Share on other sites More sharing options...
[Er...] Posted June 8, 2022 Share Posted June 8, 2022 This might help. https://windowsloop.com/fix-this-file-c ... ked-error/ Link to comment Share on other sites More sharing options...
[Mi...] Posted June 8, 2022 Author Share Posted June 8, 2022 Thanks.. I tried the global changes, but it did not work. I cant find the exe file that I need to give permission too. Also why in the hell did it work yesterday and not today????? Might have to give zeiss a call.... Link to comment Share on other sites More sharing options...
[Mi...] Posted June 8, 2022 Author Share Posted June 8, 2022 Since nothing worked, I un-installed and re-installed. So far is working as it should. Still using 21 (7.2), but will use 22 (7.4) more tomorrow and see how she acts before I turn it loose... Thanks for all the input !! Link to comment Share on other sites More sharing options...
