[Mi...] Posted June 3, 2022 Share Posted June 3, 2022 Hello everyone, I just started working with the PiWeb designer and created a report with a 3D model and MIBA flags. When the report displays the measured values, each value is displayed with different amount of digits after the decimal leaving off the 0. I have the decimal places set to 4 and 5 digits after the decimal point. Example 5.5620 is displayed as 5.562. How can I adjust the MIBA flag so that each value in the flag shows the same amount of digits after the decimal? Link to comment https://qualityforum.zeiss.com/topic/10280-miba-flag-number-length/ Share on other sites More sharing options...
[4b...] Posted June 6, 2022 Share Posted June 6, 2022 I'm not sure how to change the number of digits in a standard object, but have you considered making your own MIBA style template? Make a collection of objects that display similar information and format it the way you want. Then group them and right click "Create Element Template". In the same way that you can click & drag MIBA flags over and "drop it off" on a CAD model, you can do the same with your own Element templates. Make sure that you aren't data-bound to anything specifically when creating the template, because it will retain the data binding when you use the template object later. This is one that I created for Manual Entry reports, but you get the idea. Link to comment https://qualityforum.zeiss.com/topic/10280-miba-flag-number-length/#findComment-49188 Share on other sites More sharing options...
[Mi...] Posted June 8, 2022 Author Share Posted June 8, 2022 Thank you Laura. I will give that a try. Link to comment https://qualityforum.zeiss.com/topic/10280-miba-flag-number-length/#findComment-49190 Share on other sites More sharing options...
