[Ja...] Posted May 31, 2022 Share Posted May 31, 2022 Can anyone tell me how to program a theoretical tooling ball to measure the depth of a cone? Thanks in advance! JasonCapture3.JPG Link to comment Share on other sites More sharing options...
[Er...] Posted June 1, 2022 Share Posted June 1, 2022 Can you not get a 2mm ball to seat it on the cone and take a point, using point cloud to find the outer tangential point? You can then use caliper distance and measure the max point to the plane for your distance. Based on the tolerance you have, I would want a physical measurement. There are too many other variances going on that could make a theoretical measurement different from an actual measurement. Unless they say that this is to be a theoretical calculation. Link to comment Share on other sites More sharing options...
[Ri...] Posted June 1, 2022 Share Posted June 1, 2022 Have you looked into "Circle on a cone"?Circle on a Cone.jpg Link to comment Share on other sites More sharing options...
[Er...] Posted June 1, 2022 Share Posted June 1, 2022 From the archives.Over Tooling Ball Height.pdf Link to comment Share on other sites More sharing options...
[Er...] Posted June 1, 2022 Share Posted June 1, 2022 When I have more of an open tolerance I have measured opposite lines on a cone, created a tangent and then input the ball sized in the diameter. I then used a caliper distance selecting maximum on the tangent, and measure to the plane to get the height. This works pretty well also. I usually will check in a few places around the cone. Link to comment Share on other sites More sharing options...
