[Ku...] Posted June 9, 2022 Share Posted June 9, 2022 I have an Aramis 5M system using the 2020 software and when trying to calibrate it today I got the error in the attached picture. I am getting live images from the cameras but I am unable to acquire images. If I try to start a measuring sequence, capture a single image, or capture a reference image it just pauses and says "waiting for start signal." About 45mins before I tried to calibrate I captured a reference image without any problem. The system just sat idle for those 45mins so I don't know what could have changed. So far I have tried: I restarted the controller multiple times and the PC once. I logged into the controller IP address and reset the trigger parameters to defaults Any ideas are appreciated. Thank you Link to comment https://qualityforum.zeiss.com/topic/1033-image-snapping-error-msensorcal-0003/ Share on other sites More sharing options...
[Be...] Posted June 10, 2022 Share Posted June 10, 2022 Hi, regarding hardware related problems we recommend to contact your local GOM partner. Further information from your particular system must be collected and supplied for a deeper investigation. Regards Link to comment https://qualityforum.zeiss.com/topic/1033-image-snapping-error-msensorcal-0003/#findComment-3289 Share on other sites More sharing options...
