Profile to 2 datums, no Curve/Freeform
I need to properly measure these profiles, they are staking pockets around a bore. Datums A, D and H are all planes perpendicular to the bore, G is the bore.
I have the Zeiss Cookbook, but it seems to assume you have curve and doesn't give any instructions on how to do this.
Anything I've tried involves using space points, and datum B as a secondary datum which is a central bore on the part, parallel to to datum G...which is obviously wrong.
Do I need to be doing a geometry best fit, that references an alignment of HG, for all of the points and use that in the profile callout?3535_7c61270dcafc689675aa1cf40834220f.png
Geometry Best Fit worked well for me, in a similar measurement task, and when I got Freeform, it correlated well.
Thats great, I actually just found your post and that's where I got the idea... time to test it!
