Probing points vs circle paths
With default strategies preloaded, how do I switch a circle back to probing points, hence "measuring a diameter with a keyway?
Without obviously turning off the preloaded defaults
You could also adjust the start angle and angle range to avoid the keyway. Just a thought.
