Adding New Styluses
Hello. I just started as the CMM operator and I need to configure and qualify some new styluses. I have a Contura/RDS-CAA/VAST XXT TL3setup. I just need the step by step of adding them in and configuring them through Stylus System Creator. Thanks
I've never used SSC when creating new stylus systems and qualifying them.
My training in 2008 didn't cover SSC. 🤣
I'm curious what the advantage would be.
Apart from integrated PDF documentation, one advantage is that you can export PCF data from your offline seat, including all tip numbers, names and dimensions. Very helpful to avoid typos if you need the same probe on different machines. With VAST / XT heads you can usually run a repeated calibration (caliper button) without calibrating the stylus by hand first. Unfortunately the latter doesn't work correctly with XXT heads.
