[Ju...] Posted May 20, 2022 Share Posted May 20, 2022 Hello, Would someone please verify that the attached image of some GD&T is incorrect. I have never seen an LMC attached to a "square tolerance zone", I have always seen this with a diameter symbol in between the "position" symbol and the stated tolerance. Engineer is telling me that LMC will work in a "square zone tolerance", but I believe this to be incorrect. Thank you for taking a look, and for any info! (Please see attachment) Capture.JPGFetching info... Link to comment Share on other sites More sharing options...
[Ma...] Posted May 21, 2022 Share Posted May 21, 2022 LMC and MMC are used from element - so if they want square zone and calypso alows that, then it's ok. Just wondering what base A D locks - square zone allows more movement - perhaps they intended this because of assembly Link to comment Share on other sites More sharing options...
[SH...] Posted May 21, 2022 Share Posted May 21, 2022 Please sign in to view this quote. Do you think it is according to ASME?? Link to comment Share on other sites More sharing options...
[Ma...] Posted May 21, 2022 Share Posted May 21, 2022 Please sign in to view this quote. Not sure - I am using only ISO - not studied ASME yet, but it would not differ much. Link to comment Share on other sites More sharing options...
[Da...] Posted May 24, 2022 Share Posted May 24, 2022 Material modifiers are not always about assembly. I don't think that in this case the LMC is used for assembly reasons, because the datum A|D lets the tolerance zone rotate, which wouldn't be very useful for assembly when a square tolerance zone is used. I think, the LMC is supposed to make sure that the material width between the holes never gets too thin. I don't know what the rest of the drawing looks like, but we're talking about 1002 tiny holes. By using LMC, their distance will be controlled in a way that they can't get too close to each other. Link to comment Share on other sites More sharing options...
