Has anyone done a tooth-to-tooth adjustment based on Gearpro results?
Hello,
Again, still newbie here and learning. I guess I have 2 questions for this Topic. I will make another topic for the 3rd.
1) When you measure in GearPro, I measure Plastic Gears, does anyone on here make Tooth-to-tooth adjustments to their steel? If so, how do you go about doing it based off of the GearPro results? We take all of the data, Profile, Lead, Pitch, Left/Right, Top/Bottom, Tip Dia, Root Dia, MOW, 1039_557dff8185a0775350c6e6453518567e.jpg
and we put all of those RAW numbers into an Excel sheet. See Example below. 1039_0c63a8406bf8aa575856c560fc3c2350.jpg
2) How would you evaluate an internal gear? I ask this because I made a Tooth-to-tooth adjustment, and I fear I went the wrong direction. Data got better, but the person who made the actual WEDM moves on the tool, took my data and flipped my numbers.
Thank you in advance.
Hi Heather,
Gear Wiz here : 😉
I actually started my career in a plastic gear shop ABA-PGT in Manchester CT, 12 hour shifts all kinds of gears from small to large.
Analytical + Composite testing.
Regarding tooth thickness and measurements over/under pins or wires : I would suggest only making CTT/CSW correction based off actual measurement/dimension over/under pins/wires.
This is assuming there is no major involute or lead/helix issues going on. If you have lead / profile issues its obviously better to correct those while you have more stock, then bring the tooth into size.
Make sure your parts are cool - at proper temp.
Regarding measuring actual MBW size on internal there are a few different tools, from internal mics, dyer gages, telescope gages + micrometer. They are a bit more tricky than external especially with odd teeth.
With aerospace steel parts I can get MOW/MBW result from Gear Pro very close to actual micrometer sizes provided part is of good quality, etc. However, even then I believe Engineers and machinists always go with their actual measurements.
The issue you show below is lead error and can come from a variety of things even more so with plastics...
plastic - I would recommend composite roll testing - more economical unless these are a high spec. class grade application ,etc.
Good luck, let us know if we can help further.
