[Le...] Posted June 12, 2022 Share Posted June 12, 2022 Hi! I need to evaluate the defects of a surface and measure the deviations on the surface, I know that the program has the surface defect map, how to use it correctly? thanks, Link to comment Share on other sites More sharing options...
[Se...] Posted June 13, 2022 Share Posted June 13, 2022 Hi Leandro, The related TechGuide article(s) are a good starting point: https://techguide.gom.com/en/article/cmd_comparison_create_multiple_surface_defect_map.html https://techguide.gom.com/en/article/cmd_comparison_check_scalar_construct_user_defined_surface_classification.html If you have further questions, do not hesitate to ask. For concrete problems in certain project, you can also contact support or your local distributor. Cheers, Sergio Link to comment Share on other sites More sharing options...
