[Ky...] Posted March 24, 2022 Share Posted March 24, 2022 I've created a pallet program to run a few parts per pallet. I am trying to have the program automatically print the results to the printer before the next part is done since it will over ride the current results. I have the pdfs being saved anyway so my operators could go into the saved pdf files to print out the palleted parts before the last one but I wanted to make it automatically print and just save the step. Except every time the report prints out it prints below the paper cutting off the last measurement on the page. I've tried adjust the template in the editor to format the page to letter size. My printer default setting is letter sized (In the Calypso printer settings.) I've shortened my top margin and moved my bottom margin bigger. Despite all of this when you print the page manually it fits to the page but when automatically it cuts off the bottom every time. Is there something I am missing here to get this to fit right? Or can I create a report that will show all the parts on the pallet that I've run once they are all done? Link to comment https://qualityforum.zeiss.com/topic/10428-last-measurement-of-page-getting-cut-off/ Share on other sites More sharing options...
[Er...] Posted April 4, 2022 Share Posted April 4, 2022 I have modified my saved results to have the date and time added to the file name to avoid overwrites. Link to comment https://qualityforum.zeiss.com/topic/10428-last-measurement-of-page-getting-cut-off/#findComment-50060 Share on other sites More sharing options...
[Ri...] Posted April 7, 2022 Share Posted April 7, 2022 Please sign in to view this quote. You should use the Table Protocol - it is great for Pallets. It will hold up to 12 measurement runs on a single report. Link to comment https://qualityforum.zeiss.com/topic/10428-last-measurement-of-page-getting-cut-off/#findComment-50062 Share on other sites More sharing options...
[Ke...] Posted May 12, 2022 Share Posted May 12, 2022 Regarding the last measurement getting cut off, we now have an article on the Knowledge Base on how to fix that. https://portal.zeiss.com/knowledge-base ... &id=443321 Link to comment https://qualityforum.zeiss.com/topic/10428-last-measurement-of-page-getting-cut-off/#findComment-50064 Share on other sites More sharing options...
