Roughness Rmr measurement
Hello,
got the following Roughness on a drawing.
My thoughts are that the depth where 70% material should be is missing but i could be wrong, thats why i am asking for a second opinion here.
thanks and greetings from Germany
Daniel
Hello,
You're right. But you should look for a minimum 70% occupancy rate based on 5% filter value. Also, as you said, the depth value is missing. Generally, the desired depth is not written in the technical drawings. You can request from the customer.
thanks for the answer 🙂 helped me a lot.
its a bit hard to find information about Rmr values/variables and settings for our program (Mahr) and in general.
