[We...] Posted June 14, 2022 Share Posted June 14, 2022 I want to select the part of mesh which is outside CAD. I find the function 'select by value ' can select the part of surface comparison which deviation is more than zero,but this function is not able to select mesh. Dose have any way able to select mesh by value? Link to comment Share on other sites More sharing options...
[Na...] Posted June 14, 2022 Share Posted June 14, 2022 Hello, this is not possible at the moment but I will record this as a wish. Out of interest: what do you want to achieve with the selection? Regards, Nanno Link to comment Share on other sites More sharing options...
[We...] Posted June 15, 2022 Author Share Posted June 15, 2022 (edited) Please sign in to view this quote. Hello Nanno: Thanks for your reply . The final goal is to automatically identify areas beyond CAD and generate reports .I try to achieve this function using surface defect classification and python script .But this component is so large (5m length measuring via SB8160 with MV500 lens) that software need more than half hour to calculate surface defect classification . So we want to only select mesh areas beyond CAD to reduce the computation 。 Regards, Wenjie. Edited June 15, 2022 Link to comment Share on other sites More sharing options...
[Na...] Posted June 15, 2022 Share Posted June 15, 2022 Hello Wenjie, thank you for the explanation, I will pass this on the the development as a wish. Regards, Nanno Link to comment Share on other sites More sharing options...
[Se...] Posted June 15, 2022 Share Posted June 15, 2022 Hi Wenjie, on development side, we would like to understand why it is taking that long, and see if we can optimize it. What do you mean with "areas beyond CAD"? Areas out of tolerance on a surface comparison? Do you create the classification on the surface comparison or on a surface defect element comparison? If possible you could contact support to give further details and maybe a sample project. Regards, Sergio Link to comment Share on other sites More sharing options...
[Ja...] Posted June 15, 2022 Share Posted June 15, 2022 I am also curious as to what you want to report here ? Percentage of points outside of the cad by a certain amount ? Link to comment Share on other sites More sharing options...
