[Br...] Posted April 30, 2022 Share Posted April 30, 2022 How to set up the program before running, automatically pop up the picture, this is to remind the operator before running the program, confirm whether the amount of workpiece clamping is correct. Link to comment Share on other sites More sharing options...
[Cr...] Posted May 2, 2022 Share Posted May 2, 2022 Open the first feature that's run and insert a Programmable Stop before your strategy. Click "Select" this is where you can choose a picture.Untitled.png Link to comment Share on other sites More sharing options...
[Mi...] Posted May 2, 2022 Share Posted May 2, 2022 Do you have PCM? Do you foresee a future where you would want to do this for many programs? If you do, I would suggest doing it with PCM instead. Link to comment Share on other sites More sharing options...
[Cl...] Posted May 2, 2022 Share Posted May 2, 2022 Search the forum for "Batch file" This can be used as well. Link to comment Share on other sites More sharing options...
[Ju...] Posted May 2, 2022 Share Posted May 2, 2022 This has a PDF on creating user setup information: viewtopic.php?t=979 This has different options for when batch files are executed. (When opening the measurement plan or after clicking Run.) viewtopic.php?t=706 If you want to have a picture of the part setup in the start window: viewtopic.php?t=2425 Link to comment Share on other sites More sharing options...
