[Mi...] Posted April 29, 2022 Share Posted April 29, 2022 Hello Everyone, I would like some input on a problem I've encountered. I've measured two surfaces as free form surfaces to determine the diameter of the cylinder that will fit in the (X0, Y0) position. I've tried recalling points to a theoretical cylinder with Maximum Inscribed Element Evaluation and no luck. Here's a little illustration of what I'm working with, thanks in advance for your help. ABEND-Aperture.jpgFetching info... Link to comment Share on other sites More sharing options...
[Ma...] Posted April 30, 2022 Share Posted April 30, 2022 Did you locked coordinates ( X and Y )? Switched to inner cylinder ( hole ) Link to comment Share on other sites More sharing options...
[No...] Posted May 2, 2022 Share Posted May 2, 2022 Restricting X and Y may not be enough. If so, also restrict the vector. Link to comment Share on other sites More sharing options...
