Name definitions for output files
Hello everyone,
Is there a solution to change nr (1) and (2) at the end of the file name? Is it possible to name the two files differently?
For example:
Tapintóellenőrzés Ver.04_TP
Tapintóellenőrzés Ver.04_SP
Thanks.
Both names have same definition. Are you able to change definition independently or they share same definition ( aka you change 1st - 2nd changes automaticaly )?
I would use external script to rename last number.
You can use some time-based script, or place to inspection directory file named "report_end.bat" where you will have renaming in some way.
There is no problem with overwriting, but when you select more than one PiWeb template, then it creates pdfs with autoname number at end of name - regardeless of formula.
Look at attached picture and red mark.
I do this exact same thing and might have a solution for you. I use report_end.bat to send reports to different folders. The batch file looks for either the "(1)" or "(2)", and then send to appropriate folder.
One caveat is that you can't change order of those PiWeb reports on the mutiple print out window.
