[Ád...] Posted April 28, 2022 Share Posted April 28, 2022 Hello everyone, Is there a solution to change nr (1) and (2) at the end of the file name? Is it possible to name the two files differently? For example: Tapintóellenőrzés Ver.04_TP Tapintóellenőrzés Ver.04_SP Thanks. Link to comment Share on other sites More sharing options...
[Ma...] Posted April 28, 2022 Share Posted April 28, 2022 Both names have same definition. Are you able to change definition independently or they share same definition ( aka you change 1st - 2nd changes automaticaly )? Link to comment Share on other sites More sharing options...
[To...] Posted April 28, 2022 Share Posted April 28, 2022 This may help. https://youtu.be/xYYknavH1VQ Link to comment Share on other sites More sharing options...
[Ád...] Posted April 29, 2022 Author Share Posted April 29, 2022 Please sign in to view this quote. Exactly, my problem is that the two independent protocols share same definition. Link to comment Share on other sites More sharing options...
[Ma...] Posted April 29, 2022 Share Posted April 29, 2022 I would use external script to rename last number. You can use some time-based script, or place to inspection directory file named "report_end.bat" where you will have renaming in some way. Link to comment Share on other sites More sharing options...
[Er...] Posted April 29, 2022 Share Posted April 29, 2022 I have added the date and time from the Print Header Fields to the filenames to avoid overwriting. Link to comment Share on other sites More sharing options...
[Ma...] Posted April 29, 2022 Share Posted April 29, 2022 Please sign in to view this quote. There is no problem with overwriting, but when you select more than one PiWeb template, then it creates pdfs with autoname number at end of name - regardeless of formula. Look at attached picture and red mark. Link to comment Share on other sites More sharing options...
[Ch...] Posted April 29, 2022 Share Posted April 29, 2022 I do this exact same thing and might have a solution for you. I use report_end.bat to send reports to different folders. The batch file looks for either the "(1)" or "(2)", and then send to appropriate folder. One caveat is that you can't change order of those PiWeb reports on the mutiple print out window. Link to comment Share on other sites More sharing options...
