error while homing at start up
At start up we are getting an error while it is traveling to home causing disconnect and am unable to turn stoplight green.. The first time was end of March, then worked fine, and now is happening almost daily. We shut down complete every day as our area sees many power outages.
Found similar subject here but did not find solution. I was able to force shut down, turned on drive and move head closer to home, then started and homed ok. 2236_7f6b453b6e6a343867f5ed8f095d18a5.png
Check your ethernet cord from the CMM to your computer. Check that both ends are plugged in fully. If they feel loose I'd recommend replacing the cord
Try turning down the speed before homing, I had this issue after a Zeiss calibration. The tech had altered a parameter and had to set it back.
