[La...] Posted March 24, 2020 Share Posted March 24, 2020 Is there a way to put the Calibration Date in the header of a report similar to putting the CMM Machine Number? Link to comment Share on other sites More sharing options...
[Ow...] Posted March 24, 2020 Share Posted March 24, 2020 Which report are you using? Custom Report or Pi-web? Link to comment Share on other sites More sharing options...
[La...] Posted March 24, 2020 Author Share Posted March 24, 2020 Custom Report. I'm not a fan of Pi-Web at the moment. Link to comment Share on other sites More sharing options...
[Da...] Posted March 25, 2020 Share Posted March 25, 2020 Larry, I could do it without much effort with PCM but I don't know if you can do it without. It looks like the fields are locked so I'm not sure if you could add them. You could add them to a input field but that would require updating each time If I find a way I will let you know out side of PCM Thank Dan Link to comment Share on other sites More sharing options...
[Ma...] Posted March 25, 2020 Share Posted March 25, 2020 If you want a manual chang in the protocol you can try this maybe its okay for you: you can make two text field in the protocol header. an you must change the date every year. 😉protheader.pdf Link to comment Share on other sites More sharing options...
[La...] Posted April 20, 2022 Author Share Posted April 20, 2022 Thank you Marti! Finally followed your suggestion. We had just used a text element for a while, and I didn't like it because we had to mask on one machine and unmask and vise versa. Again, thank you!!! Link to comment Share on other sites More sharing options...
[Ma...] Posted April 27, 2022 Share Posted April 27, 2022 😉 welcome Link to comment Share on other sites More sharing options...
[SH...] Posted April 27, 2022 Share Posted April 27, 2022 Please sign in to view this quote. You should be, Zeiss has removed custom report editing (inside resources window) from calypso 2022. Link to comment Share on other sites More sharing options...
[La...] Posted April 27, 2022 Author Share Posted April 27, 2022 Thank you for the info Shabu! I am at a small shop and our needs call for documentation to be simple and concise. We are running Calypso 2017 right now. Link to comment Share on other sites More sharing options...
[Je...] Posted April 27, 2022 Share Posted April 27, 2022 Please sign in to view this quote. Shabu, Did they release Calypso 2022 yet? I don't see it listed on the portal site. . Link to comment Share on other sites More sharing options...
[Ch...] Posted April 27, 2022 Share Posted April 27, 2022 Please sign in to view this quote. Wow, I believe this is possible from Zeiss ... Shabu, can you confirm where you heard this ? I'm wondering if we will stall PCM access to custom report fields too .. We're going to 2021 from 2017 any time now ... Link to comment Share on other sites More sharing options...
[SH...] Posted April 28, 2022 Share Posted April 28, 2022 Please sign in to view this quote. Recently I had a Zeiss cock book training with a senior application engineer, told me they have removed bottom half of the pull down window, I have attached.. Also there is lot of change in the software interface, feature colour has been changed to black and white from colour..etcIMG_20220428_144839.jpg Link to comment Share on other sites More sharing options...
[SH...] Posted April 28, 2022 Share Posted April 28, 2022 Please sign in to view this quote. Yes it is not released yet.... Link to comment Share on other sites More sharing options...
[Je...] Posted April 28, 2022 Share Posted April 28, 2022 Please sign in to view this quote. Chris, You probably are doing so, but I highly recommend you fully test Calypso 2021 on one machine/customer part before making the upgrade, or you could be opening Pandora's box. Link to comment Share on other sites More sharing options...
