Differend nominal diameters
Hello there,
I was wondering if somebody has an answer to my question.
I would like to measure several ring gauges with different diameters in autorun. I therefor have to fill in a nominal diameter somewhere before running the autorun. I have made the program to measure diameters from Ø4 to Ø80mm. 5171_76b2e7d3b3ed9db7bf8d73b623fe6780.jpg
The diameter has to be transfered to the characteristic. 5171_a68a84efad753405702a054cb384f91a.jpg
Thanks for you're help!
You can the prompt operator to input the nominal diameter using Result Element, then just reference this diameter with formulas in the pertinent Features and Characteristics.
