[ja...] Posted April 22, 2022 Share Posted April 22, 2022 hello everyone How to change the stylus system and stylus of elements through PCM? Thank you very much for your helpbbbbbbbbb.pngaaaaaaaaaa.png Link to comment Share on other sites More sharing options...
[Se...] Posted April 22, 2022 Share Posted April 22, 2022 Hi, unfortunately, its seems you cannot do it in the editor. You will have to do it in each feature itself... Link to comment Share on other sites More sharing options...
[Ma...] Posted April 22, 2022 Share Posted April 22, 2022 In this window you can change only Stylus system for whole plan, but only if you set there "Default" for all elements. But this won't change Stylus. Here you even can not use PCM. Link to comment Share on other sites More sharing options...
[He...] Posted April 22, 2022 Share Posted April 22, 2022 In the clearance data window you can input a formula in the field for stylus system and the same can be done in the strategy for stylus. Then you can use the paint brush tool and transfer those settings to other features. Link to comment Share on other sites More sharing options...
[Jo...] Posted April 22, 2022 Share Posted April 22, 2022 Please sign in to view this quote. or Resources>Stylus System>Exchange Stylus Name may work Link to comment Share on other sites More sharing options...
