[Ja...] Posted April 14, 2022 Share Posted April 14, 2022 I have a part that has 3 pads (not real large) on opposite sides of each other. One set of pads is established as Datum A and has a Flatness callout of .0002" (three surfaces) the other is a callout of Parallelism of .0002" to Datum A (three surfaces). I have scanned all pads individually then recalled them into one plane each. I then call out my Flatness to the one plane and my Parallelism using both planes as stated per print. the problem is doing an indicator check on a surface plate vs. what we are doing on the CMM we are getting completely different results. Why?????Capture.PNG Link to comment https://qualityforum.zeiss.com/topic/10594-parallelism-and-flatness-of-3-surfaces/ Share on other sites More sharing options...
[Ow...] Posted April 14, 2022 Share Posted April 14, 2022 A few questions: Between indicator vs CMM, which characteristic are are you seeing the biggest difference, Parallelism or Flatness? What do the plots look like, does it show any odd ball spikes that may not be filtered out adequately? I assume you're holding the part parallel to the Z axis and scanning it with two different probes, how confident are you that the part is being secured enough to not deflect or move? Link to comment https://qualityforum.zeiss.com/topic/10594-parallelism-and-flatness-of-3-surfaces/#findComment-51022 Share on other sites More sharing options...
[Ri...] Posted April 14, 2022 Share Posted April 14, 2022 0.0002" is extremely tight of a tolerance. You would need a machine that was accurate within 0.0005µm. There are so many questions that could be asked: How accurate is the indicator? Are the parts clean? How stable is the environment? How many points are you scanning? Speed? Probe size? Filter? Outlier Elimination? What type of CMM is this? What sensor are you using? Link to comment https://qualityforum.zeiss.com/topic/10594-parallelism-and-flatness-of-3-surfaces/#findComment-51024 Share on other sites More sharing options...
[Ja...] Posted April 14, 2022 Author Share Posted April 14, 2022 I have the Filters and outliers turned on. The Flatness is always checking between .00008-.0001 and it is the Parallelism that is off usually two of the three pads are off a little but not always the same ones either. Part does not move at all. Form looks great on all 6 pads. Probes are clean. Same speed on all pads. Datum A pads are helping establish the base alignment in Z. Link to comment https://qualityforum.zeiss.com/topic/10594-parallelism-and-flatness-of-3-surfaces/#findComment-51026 Share on other sites More sharing options...
[Ja...] Posted April 14, 2022 Author Share Posted April 14, 2022 Richard- Indicator used .00005" 300 points per pad .3 Speed Filter on Outlier on 1mm probe Accura Vast XTGold Parts always cleaned before run Stable environment 68° Link to comment https://qualityforum.zeiss.com/topic/10594-parallelism-and-flatness-of-3-surfaces/#findComment-51028 Share on other sites More sharing options...
[Ch...] Posted April 14, 2022 Share Posted April 14, 2022 What about the evaluation method on each feature (Tangent vs LSQ)? Link to comment https://qualityforum.zeiss.com/topic/10594-parallelism-and-flatness-of-3-surfaces/#findComment-51030 Share on other sites More sharing options...
[Ja...] Posted April 14, 2022 Author Share Posted April 14, 2022 LSQ Link to comment https://qualityforum.zeiss.com/topic/10594-parallelism-and-flatness-of-3-surfaces/#findComment-51032 Share on other sites More sharing options...
[Da...] Posted April 15, 2022 Share Posted April 15, 2022 So, is the part standing up on edge so you can access both sides ? OR are you putting datum A on the surface plate of the cmm? How big (rough diameter) is the part, and how thick is it ? Material ? Link to comment https://qualityforum.zeiss.com/topic/10594-parallelism-and-flatness-of-3-surfaces/#findComment-51034 Share on other sites More sharing options...
[Je...] Posted April 15, 2022 Share Posted April 15, 2022 . It's second shift's fault. . Link to comment https://qualityforum.zeiss.com/topic/10594-parallelism-and-flatness-of-3-surfaces/#findComment-51036 Share on other sites More sharing options...
[Er...] Posted April 15, 2022 Share Posted April 15, 2022 What are the readings from each method? I would assume the CMM passes what the granite fails? Have you tried measuring on a different piece of granite? Ours is worn in different spots, but still passes certification. And it has chips. 🤣 The granite should touch the most extreme points on Datum A. The CMM would have to hit those exact points to get the exact same reading. Datum A being a smaller diameter would magnify the differences to the pads on the edge. Link to comment https://qualityforum.zeiss.com/topic/10594-parallelism-and-flatness-of-3-surfaces/#findComment-51038 Share on other sites More sharing options...
[Dy...] Posted April 15, 2022 Share Posted April 15, 2022 Have you tried making 1 plane and take points on all 3 pads in the same strategy instead of recalling them? I've just personally seen some issues where recalling multiple planes into one skews my results. Link to comment https://qualityforum.zeiss.com/topic/10594-parallelism-and-flatness-of-3-surfaces/#findComment-51040 Share on other sites More sharing options...
