[Mi...] Posted April 13, 2022 Share Posted April 13, 2022 when traveling in the Y direction only, head will lunge forward or backward sometimes even when you put the least bit of pressure on the joystick. if I am in a small ID I will click the >> > button on the control box and sometimes it will travel extremely slow and take the point or kick the drive out as soon as I touch the joystick. Any ideas what is going on here I am running a Contura Select with VAST XT Gold Head running 2019 version 6.8624 Thanks in advance for your help Link to comment https://qualityforum.zeiss.com/topic/10606-rapid-travel-in-y-axis-when-i-dont-want-it/ Share on other sites More sharing options...
[Ju...] Posted April 13, 2022 Share Posted April 13, 2022 Sounds like you might need to re-calibrate the joystick on the controller. viewtopic.php?t=3202 Link to comment https://qualityforum.zeiss.com/topic/10606-rapid-travel-in-y-axis-when-i-dont-want-it/#findComment-51144 Share on other sites More sharing options...
[Mi...] Posted April 13, 2022 Author Share Posted April 13, 2022 thanks Justin. I will try this out this aftrnoon Link to comment https://qualityforum.zeiss.com/topic/10606-rapid-travel-in-y-axis-when-i-dont-want-it/#findComment-51146 Share on other sites More sharing options...
[Mi...] Posted April 13, 2022 Author Share Posted April 13, 2022 Justin thanks it worked perfectly Link to comment https://qualityforum.zeiss.com/topic/10606-rapid-travel-in-y-axis-when-i-dont-want-it/#findComment-51148 Share on other sites More sharing options...
