Rapid Travel in Y Axis when I don't want it
when traveling in the Y direction only, head will lunge forward or backward sometimes even when you put the least bit of pressure on the joystick. if I am in a small ID I will click the >> > button on the control box and sometimes it will travel extremely slow and take the point or kick the drive out as soon as I touch the joystick. Any ideas what is going on here
I am running a Contura Select with VAST XT Gold Head running 2019 version 6.8624
Thanks in advance for your help
