Can't change tolerances in degrees, minutes, seconds
This problem has been going on for almost 2 years since version 6.?
I cannot change the tolerances of angles if I have the settings in degrees, minutes, seconds.
Whenever I adjust the tolerance and press OK, the tolerance jumps back.
This problem also occurs when I want to change a circlescan for example to 180 degrees, It also jumps back to 360 degrees preset.
To get around this problem I have to change through language to dec. degrees change the settings and you back to deg.min.sec.
I submitted this problem to the Dutch Zeiss helpdesk and they forwarded it to Germany. I haven't heard back from them.
With every update of Calypso I hope the problem is solved.
I am using HP PC with Windows 10 provided by Zeiss with Calypso 7.2.08.
Hi Jeroen,
I am unable to replicate your issue.
Have you tried creating a fresh installation of Calypso? I've had issues with the C++ patches getting corrupted, and I had to nuke the install, and start over. It's painful, but it tends to get rid of a lot of bugs.
You can create backups of your user data, so you don't have to re-create your setup as well.
Hi Richard,
Installing Calypso from scratch is at the time a bridge too far.
I'm hoping for a simple solution at the time, but if there is none I will consider your option.
