[Ja...] Posted April 8, 2022 Share Posted April 8, 2022 I have a circle that's built from points I've pulled out of some curves using PCM. The program works fine except I get the error "Access attribute not allowed for access object!" when I do a subsequent evaluation. After clicking Ok for every instance the subsequent evaluation continues and everything comes out fine. If I put a characteristic or some PCM before the circle evaluation that uses the points the circle is built with, the issue goes away. So its like for some reason Calypso doesn't calculated the points (even though I'm running the SE to feature list) until it gets to the characteristic that is evaluating the circle and then it throws a fit and then goes back and calculates them so it can create the circle. Has anyone else experienced this? Is this just a bug with 6.6.1601? Or did is there maybe something I did wrong here? Link to comment https://qualityforum.zeiss.com/topic/10636-pcm-and-subsequent-evaluation/ Share on other sites More sharing options...
[Er...] Posted April 9, 2022 Share Posted April 9, 2022 I've had similar issues when pulling points with version 5. No PCM involved. It's like Calypso is getting ahead of itself. If I put something between the feature and pulled points it does ok. Link to comment https://qualityforum.zeiss.com/topic/10636-pcm-and-subsequent-evaluation/#findComment-51280 Share on other sites More sharing options...
