[Th...] Posted April 5, 2022 Share Posted April 5, 2022 Is it possible to import models of extensions and holders into the Stylus System Creator? Untitled.pngFetching info... Link to comment Share on other sites More sharing options...
[No...] Posted April 7, 2022 Share Posted April 7, 2022 No. As far as I know, the file format of the SSC models is proprietary. Zeiss may be able to include customer-specific elements in the database, but not for free of course. You can model your own probes to a certain extent by using the available generic shapes. This is limited of course, but you can often break up a needed shape into several generic shapes. A simple example: If you need a connection at a specific height of a cylinder, you can achieve it by combining 3 separate cylinder shapes: the first one of length A (up to the connection height), the second one of height 0 (only providing the 4 connections) and the third of length B (rest of the cylinder). The shapes you build that way can be exported as separate SSC shapes and later be imported and attached to a connection point. Link to comment Share on other sites More sharing options...
