CMM Error when homing the axis
It's happend when the machine was near the end position and you sent machine to the home position?
In my case, the zeiss technician has set me overload protection for X or Y axis. Changed nominal force for overload.
Monday morning I have to clean really good or I sometimes get errors.
I also use the control box to home. I get more errors if Calypso does it for some reason.
Try with lower speeds when homing.
I also get some errors when homing with the control box but not like yours; in my case, drives dont turn off or anything, there are errors in status window only about limit and travel command rejected. This didn't use to happen in earlier version of Calypso.
