setting up multiple versions
So changed jobs and I now have 9 CMMs and a planner seat.
4 CMMs are running 6.2, 1 is running 6.4, 3 are running 6.8 and and O-inspect is 7.0.
My planner seat is running 6.2 but I am updating license to latest version ASAP.
Until I can get everything setup with current license I need to program for all the systems offline.
Would I need to install 4 versions to edit offline for all systems or could i install 7.0 and save as earlier?
I would think once I install 7.0 I could not install 6.4 or 6.8 so I am hoping someone has done this before with some insight.
Installing all 4 versions is not such a bad idea. Even if you won't need it right now, maybe you will, later.
Just be carefull with order, install the oldest first and continue to the newest.
  • 7 months later...
