[Op...] Posted August 26, 2020 Share Posted August 26, 2020 Hello everyone, I am pretty new with calypso software. In the piweb report the deviation band it shows me the nominal value and I want to show me the center of the tolerance, where do I find these settings? Ex: The dimension is 20 - 0.1, in piweb report on +/- band the center of this dimension is 20(nominal),I want to change so the center would be - 0.05. Can someone give me some hints? Link to comment Share on other sites More sharing options...
[Ün...] Posted August 26, 2020 Share Posted August 26, 2020 If you write the measure value as 19.95 ± 0.05 in the program in Calypso, the nominal value appears as 19.95 in piwep. This is how I solve it. Link to comment Share on other sites More sharing options...
[Op...] Posted August 26, 2020 Author Share Posted August 26, 2020 I know, but for example:I have on drawing 20 -0.1. I want on report to have nominal value 20 and deviation +/- band to show the center of the tolerance 19.95. If I change the nominal value in 19.95 than on report will appear 19.95 as nominal which is not ok with the drawing Link to comment Share on other sites More sharing options...
[To...] Posted August 26, 2020 Share Posted August 26, 2020 Please sign in to view this quote. The drawing indicates a single sided tolerance so unless you do what Unal suggested, I’m guessing you’ll have to live with a single sided deviation graph. Link to comment Share on other sites More sharing options...
[Op...] Posted August 26, 2020 Author Share Posted August 26, 2020 Thank you, than can I atleast change the values that it shows at deviation to show the correction needed till the center of tolerance ? Now it shows how much correction it needs till the nominal. Link to comment Share on other sites More sharing options...
[Za...] Posted August 26, 2020 Share Posted August 26, 2020 Put reference dimensions on the report to help them find the center. Depending on the feature and your alignment it could be as simple as using your x-y dist from the feature. Just check the box to remove the tolerance if that is an issue with the references. Link to comment Share on other sites More sharing options...
[To...] Posted August 26, 2020 Share Posted August 26, 2020 Please sign in to view this quote. I prefer to do it that way, too. Link to comment Share on other sites More sharing options...
[Op...] Posted August 26, 2020 Author Share Posted August 26, 2020 There must be some settings, because we have 2 duramax one with calypso 2018 and the new one with calypso 2019. The older one with calypso 2018 is working fine the reports are they way I want, but the second one have the problem described. I also copied the programs from the older duramax to the newest and same problem and I looked everywhere, all the settings I know to see if it is some difference, but nothing. Link to comment Share on other sites More sharing options...
[To...] Posted October 1, 2020 Share Posted October 1, 2020 Please sign in to view this quote. I had the same problem. And made this which seems right. How did I do this? I really can't remember. But I think it were some place in the properties of the tolerance bar. Link to comment Share on other sites More sharing options...
[To...] Posted October 1, 2020 Share Posted October 1, 2020 Please sign in to view this quote. I believe you should copy the report template instead of the program. Link to comment Share on other sites More sharing options...
[87...] Posted October 2, 2020 Share Posted October 2, 2020 Open the PiWeb report template in the Designer (editor). Go to File > Configure tolerance limits > In the dialog that opens, select use custom configuration. At the bottom, change the dropdown from Nominal to Middle of Tolerance. Link to comment Share on other sites More sharing options...
[Se...] Posted March 17, 2022 Share Posted March 17, 2022 I cannot find this setting. Does anybody knows if it is available with PiWeb reporting ? (no PiWeb reporting plus here...) Link to comment Share on other sites More sharing options...
[Gu...] Posted April 3, 2022 Share Posted April 3, 2022 This can also be changed with CALYPSO Standard: Windows Start / ZEISS CALYPSO xx / PiWeb reporting plus (can be done without a license). Options (Gear icon) => Tolerance usage mode Link to comment Share on other sites More sharing options...
