PCM / Bad Report
I'm looking for PCM code that will send an out of tolerance report to a different folder than were it sends an in tolerance report.
That 2nd link that Kevin posted.
InspectionToleranceState is a piece of code i found that works well for sorting good vs bad.
In my situation i used it to delete the TXT file i was creating for export, but you can just as easy use it to divert the report to a different folder.
Unfortunately my new masters dont use PCM, so i cant work on code anymore.
