Not able to import STEP files
We just got a new DuraMax and it is unable to recognize and import STEP files. The drop down only shows SAT (ACIS) and DXF files. The older CONTURA is able to recognize SAT (ACIS), STEP and DXF files.
At the time we got the CONTURA (2013) I thought I was told that these three came standard. Did they remove the STEP file translator so now we need to purchase it separate or am I missing something in the settings to turn this on?
Or. He can use CONVERT ON BACKGROUND. This mean, that open blank new measuring plan, use CONVERT ON BACKGROUND and Calypso convert selected STP to SAB in the same folder and same name like STP.
either step or iges should have come standard with the machine. However, I believe the DuraMax LTE does not include either of these. I also believe the dxf converter is an option but since you use it, maybe you ordered it.
I think it depends upon the the licence we have.My last company has only Calypso licence, could only work with step files, previous company had curve and freeform licence i could open both step ang iges files..
