Trig Help - Sphere seated in Cone
I had someone help me with this years ago, and now I'm struggling.
I have a 120° Cone that I need to calculate the height of a theoretical sphere (3") seated into it. The only part of the equation that I remember is that you have to start at the origin of the cone (or that was how this particular person calculated it).
I do not want to use lines and a tangent construction - I want to be able to calculate it directly from the cone.
Any and all help is greatly appreciated.
I often keep notes of things I think I might need one day and found this.
Gauge Ball in Cone Formula:
measure the cone
open result element
right click in the formula field and select formula
((cos(half cone angle)*(gage ball radius) * 2 open cone calculation
check Position definition
right click and select formula
select (result element get actual result) + ((sin(half cone angle)) * gage ball radius) + gage ball radius
Owen,
I don't know why, but mine works out differently. Another thing I learned is that I have to use the Deg function, and for whatever reason Calypso wouldn't pull the angle from the feature directly, so I had to create the half cone angle characteristic.
Here are the steps that I had to use to get the correct answer.
In Calypso 2021:
Create a Half Cone Angle Characteristic for your Cone
Create a Result Element and use the following formula:
((cos(deg(getActual("Half Cone Angle1").actual))*Gage Ball Radius)*2)
Create a Cone Calculations Feature, select Position Definition, and use the following formula:
(getActual("Result Element1").actual) + ((1/cos(deg(getActual("Half Cone Angle1").actual)))*Gage Ball Radius)+Gage Ball Diameter
