Creating diameter from section cone, plane
Hello,
Hope someone can help me here. I can't find a way to determine a diameter created from an intersection from a cone with a plane.
I am sure there must be an easy way, but I can' t find it.
Hello Bram,
there is an intersection ellipse cone/plane in the construction menu. Another approach is to construct an intersection curve from geometrical elements -> RMB on curve -> select all points of element -> create fitting circle -> referenced construction.
Regards,
Nanno
  • 5 months later...
[Edit previous post sorry 😬]
Hello,
That helped me a lot too, thank!
0.001 mm difference between two methods.
Have you a method to make intersection between two cones please ?
Best regards.
Edited
Hi Gouret,
there is an intersection curve, which will work for cones:
https://techguide.gom.com/en/gom-software-2022/article/cmd_curve_create_curve_by_element_intersection.html
The elements have to intersect though, so you might have to edit the size in the properties. Depending on your inspection you could also use a cylinder/cone based section (https://techguide.gom.com/en/gom-software-2022/article/cmd_section_create_multiple_cylinder_based_section.html).
Regards,
Nanno
